Questions regarding LT4 ED timing chain setup
I've searched but didn't find an answer to my question. I have an 03 LT1 that I'm doing a twin turbo build. I have eliminated the opti spark. My turbo cam has a pin length of app. .820". Is that long enough for the LT4 ED chain/gears, or does it not matter since the opti is gone? Can I use the stock timing cover or must it be swapped for the later style (again no opti)? Seems like I'm good to go as-is but just wanted to verify before ordering the parts.
Thanks for your time.
Jody
Jody
Re: Questions regarding LT4 ED timing chain setup
What kind of water pump are you going to run Std? or electric? If you deleted the opti and want to run a electric pump i believe then you can use any small block chain out there. If not you probably just want to go with a cloyes double roller considering the power out put your wanting to do.
I'm going to run the standard LT1 pump. So I still need the pump drive. From what I'd seen you can't run the Cloyes without going to an electric pump.
Thanks.
Jody
Thanks.
Jody
