questions on lca'a panhard, subframes
Old Feb 11, 2004 | 07:43 AM
Coolformula's Avatar
I made a post in auto x but that formun is really slow on talking. I think of getting the hotckis kit adj panhard etc.
1. Will these parts save weight any?
2. Could you tell a differnce in them?
3. How much weight on the DD subframes and what dop you think of them?
thanks
Old Feb 11, 2004 | 07:52 AM
4. Which subrame combo.
Kenny DD with a bmr tunnel brace
LG with x brace
LG v brace
5.
If I do subframes can I still lower my car?
6. If not, which is better subframes or lower my car for better handling?
Old Feb 11, 2004 | 08:22 AM
brokenz's Avatar
In my opinion, any tubular, weld in sub frame connector will be all right. I'm using Global West because they had a good special back when I bought it. The car is definitely better on launch and corners. Better in that it no longer creaks and moans and as a bonus all my rattles magically disappeared.
Old Feb 11, 2004 | 08:24 AM
brokenz's Avatar
Also, if you do Global West subframes then you can still lower your car. The subframe connectors will not be the lowest point. I'm sure this is probably true of most brands. I also liked the fact (back when my car was lowered) was that the subframes were a piece of tubular steel protecting the car when I went over speed bumbs the wrong way.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Skull Leader
Aug 10, 2002 11:01 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
