Questions about switching to Synthetic on a stroker
Old Jun 20, 2003 | 02:44 PM
Gripenfelter's Avatar
I've broken my motor in for 7000 miles on dino oil 10W40.
The engine builder recommended 15W40 in hot weather and 10W40 in cooler weather.
If I switch over to Royal Purple Synthetic, will using 15W40 be a problem?
How much thinner is Royal Purple synthetic?
Old Jun 20, 2003 | 03:56 PM
TedH's Avatar
I would ask your engine builder. He built it within a certain tolerance and he will provide you the most accurate answer.
My engine builder built mine to use 20-50. He said I could change to synthetic whenever I wanted after it was broken in.
Old Jun 20, 2003 | 04:03 PM
bruecksteve's Avatar
If read many automotive engineers say it doesn't matter. Porsches, Corvettes, Vipers, Cobra R's, AMG Mercedes and others come that way from the factory (Mobil 1). The Chevy engineer said that they found it actually helped (some long explaination, I'll try to find it) with seating the rings.
Old Jun 20, 2003 | 04:06 PM
got_hp?'s Avatar
id be willing to bet that is a marketing deal or incentive.........mobil supplies it for dirt cheap and gets to say that auto manufacturers "choose" mobil because its the best.
Old Jun 20, 2003 | 04:16 PM
Good reading http://www.syntheticoiltech.com/oil/...KeptSecret.htm
Old Jun 20, 2003 | 05:04 PM
Vader's Avatar
The only concern with using synthetics early in a rebuilt engine's life is ring seating. With modern machine honing techniques and ring materials, even that concern is normally eliminated.
Mobil 5W30 is good enough for a 400 horse ZO-6, its good enough for me.
I can see no use for increased bearing clearances, and an attempt to "fill" them with a heavy oil is a waste of time. Both Honda and Ford has reduced bearing clearances recently, and now specify a 5W-20 oil under the new GF-3 ILSAC spec.
I have never understood the idea of extended drain intervals, and there is no evidence that any engine needs greater filtration than that provided by the stock filter. Below a certain size, particulates do not cause wear. Chemical contamination and degradation dictate oil drain intervals, not particulates.
Old Jun 20, 2003 | 05:22 PM
I swear by Mobil 1. My LT1 has 148,000 on it and doesn't burn a drop of oil between my 5,000 changes. I still run 5-30.
Old Jun 20, 2003 | 05:28 PM
got_hp?'s Avatar
to quote brent from another thread
"This reminds me and I'll bring up something else... we don't "change" our 20,000 gallon plus turbine lube oil system. We constantly filter it. This oil gets used for 2 years straight (24 hours a day 7 days a week) then gets put through a centrifuge and used another 2 years and so on. Basically, just pointing out that oil doesn't get old or go bad... it gets contaminated. "
im guessing that unfiltered particles contribute to the "contamination" that ruins oil..............so the better filtration you can get, the better your oil will be.
Old Jun 20, 2003 | 07:33 PM
Vader's Avatar
It is not possible to compare a steam turbine lubrication system with that of a hydrocarbon fueled piston internal combustion engine. The operating requirements are completely different. Even gas turbines (turbojets) have different requirements.
In diesels, particulates (soot) do contribute, but are vastly greater in quantity than anything a modern gasoline engine will produce. No amount of filtering will change the chemistry of the oil, as filtering is strictly a particulate removal process.
Use good oil, of the appropriate viscosity and service requirement, synthetic preferably, and change it and the filter regularly. That's all there is to know.
rideordie
Nov 5, 2019 04:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
