questions about installing CSI water pump
Old Feb 20, 2004 | 06:59 AM
meangrn94ta's Avatar
I'm installing the CSi water pump on my 94 T/A and i am also doing a cam swap. one i put the new timing chain back on what or how do i get rid of the gear that drives the water pump. i took the 2 hex head screws out but it wont pull out. does anyone know if i can just leave it in it place with a new double roller timing chain?
please help
thanks
Mike LaBarbera
812-760-7553
Old Feb 20, 2004 | 07:14 AM
john97z28's Avatar
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
I followed the directions for the pump install. I didn't remove the shaft though. I'm doing my cam install in the spring and plan on doing it then. Hope this helps.
Old Feb 20, 2004 | 07:19 AM
thanks they are say just to use a bar and pop the damn thing out.
SnakEaterZ28's Avatar
Just with the intake off...hit it from the back with a socket and a hammer and it will come right off
Old Feb 20, 2004 | 07:28 AM
do i need to put a freeze plug in place of the shaft or can i just leave it open which di u so snakeeater?
Old Feb 20, 2004 | 08:17 AM
GREGG 97Z's Avatar
I just knocked that shaft out with a center punch and a hammer, it came out pretty easily. I left the hole open, I was told it didn't matter if you plugged it or not and it's been fine since.
Old Feb 20, 2004 | 08:18 AM
jkipp84's Avatar
Same here. No problems.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
