questions about installing CSI water pump
I'm installing the CSi water pump on my 94 T/A and i am also doing a cam swap. one i put the new timing chain back on what or how do i get rid of the gear that drives the water pump. i took the 2 hex head screws out but it wont pull out. does anyone know if i can just leave it in it place with a new double roller timing chain?
please help
thanks
Mike LaBarbera
812-760-7553
please help
thanks
Mike LaBarbera
812-760-7553
http://ken.lowrance.com/Projects/CSI...mp/Default.htm
I followed the directions for the pump install. I didn't remove the shaft though. I'm doing my cam install in the spring and plan on doing it then. Hope this helps.
Originally posted by GREGG 97Z
I just knocked that shaft out with a center punch and a hammer, it came out pretty easily. I left the hole open, I was told it didn't matter if you plugged it or not and it's been fine since.
