Question Regarding Opti Vac. Harness
Old Jul 17, 2005 | 11:00 PM
ibanez6rg's Avatar
Just got finished putting the Vette back together and it seems the line from the opti to the intake elbow got ripped apart. Is it OK to drive with it like that for the time being?
Old Jul 17, 2005 | 11:04 PM
turbo_Z's Avatar
Re: Question Regarding Opti Vac. Harness
Its a vacuum leak... very small one but still a vacuum leak. I doubt youd ever notice a difference in the way the car drives but why not just fix the tear with some black tape till you find a replacement hose?
Old Jul 17, 2005 | 11:06 PM
If the vacuum side of the harness is connected, you will be pulling unfiltered air into your opti. If only for a short time, you might just cap the ports on the opti and also at the intake. You should also plug the hole in the intake elbow.
Old Jul 17, 2005 | 11:17 PM
ibanez6rg's Avatar
The problem is, the tear is where we can't get to on the end of the opti. On Vette's it's impossible to mess around with the Opti, unlike our cars. Should the vacuum side of the harness be blocked off until it gets fixed, Rob?
Old Jul 17, 2005 | 11:20 PM
Yeah, I think I said to cap off the vacuum at the intake.
Old Jul 17, 2005 | 11:34 PM
ibanez6rg's Avatar
Yeah... I know... I was just making sure you knew what you were talking about.
Old Jul 17, 2005 | 11:37 PM
It's always good to check. Sometimes I get confused.
Sergio
Jan 27, 2016 04:27 PM
jayvar
Feb 2, 2015 10:00 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
