question on power loss (after gutted cat)
Old Nov 27, 2003 | 08:54 AM
predator's Avatar
can this cause power loss? it seems after this was done my car has lost its umph
Old Nov 27, 2003 | 11:58 AM
$hawn's Avatar
No, cant cause a power loss, but it more than likely shifted the power and torque range.
Old Nov 27, 2003 | 12:00 PM
predator's Avatar
just feels like off the line until about 1500 i have no power now and in 2nd gear punch it bogs all the normal stuf is new opti exetra
Old Nov 27, 2003 | 12:12 PM
brandboZ28's Avatar
How it was explained to me is that with the cat in place, you have plenty of backpressure which helps produce low end torque. When you get rid of a cat or in your case, gut it, you lose that back pressure and the torque you are so used to having down low has moved up the rpm range just a bit. I recently removed my cat, agian, and its true, you do lose some low end torque but gain plenty of top end power from it.
Old Nov 27, 2003 | 02:42 PM
b-stevens's Avatar
What year?
Old Nov 27, 2003 | 03:09 PM
predator's Avatar
94
Old Nov 27, 2003 | 07:41 PM
Z95m6's Avatar
When i had my off-road pipe i was picking up false knock almost 5 degrees at idle and when i put a cat, back on the car it all went away. Needless to say i picked up alot of power going back to the cat setup and the car sounded much better.
thenewkid
Nov 27, 2014 09:41 AM
tubby
Oct 13, 2003 09:16 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
CamaroZBoy
Aug 19, 2002 12:41 PM
CamaroZBoy
Aug 16, 2002 10:03 PM
