Question on LCA install?
Old Oct 8, 2003 | 10:31 PM
LimitedEd1LE's Avatar
I just got the BMR LCA's and I was wondering if there are any tricks out there for installing them. I don't have a lift. Do I just have to get the weight off the rear? Should I use an air wrench on the bolts or can I just tighten them as much as I can? Any help would be appreciated.
Old Oct 9, 2003 | 01:27 AM
94formulabz's Avatar
Originally posted by 2CNTRY
It is preferable to keep the car loaded (no jacking), thus preventing binding.
agreed. You probalby want the car supported by jackstands and the axle by a floorjack to get the bolts lined up. Then put the jackstands under the axles and support it by them while you tighten them down to the torque spec on BMRs website
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
lbrowne
Nov 13, 2011 04:25 PM
Chrisdude
Jul 24, 2002 02:25 PM
