Question on High stall (3000-3500) on Stock Heads/cam
Old Feb 24, 2005 | 08:05 PM
  #16
maroon94z's Avatar
Re: Question on High stall (3000-3500) on Stock Heads/cam
I just went with an Edge 3000 rpm stall, and picked up 4 full tenths in the 1/4 mile. I'm a bracket racer, so I have extensive records of how my car performs in every weather condition, so you can take that 4 tenths to the bank. I also got the high stall problem after 4 passes down the track, but that should be fixed now, just waiting for Saturday to try it out. You will notice a difference in driveability, but you'll get used to it. IMO, 2800-3000 is perfect for stock motored cars. Anything less, and you'll be disappointed. Call Andre at Edge if you have any questions.
Bill
Old Feb 24, 2005 | 08:14 PM
  #17
indieaz's Avatar
Stock our cars make lots of torque down low. Like mentioned above - most manufacturers over-rate their converters and they actually stall sooner than advertised. However, that said - a 3600 converter would be ridiculous on a stock car as your are losing some of your power band. To a degree your engine builder is right - if you have a converter with a true stall speed of 3200 that is going to be sort of a waste and you are cutting out some of your power band. However, the converter will generally not stall at as high a speed as is advertised.
That said, OBD1 cars (excluding '93 which does not have the 4l60-e) sometimes have trouble with converters that stall in the 3000+ range. Tuners can supposedly fix this - but custom tuning is an added expense. I would just go for a 2800 converter personally. Wish i had gone with a 2800 on my car
HectorM52
Jun 23, 2016 08:42 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Cam's maro
Dec 28, 2014 09:30 AM
F(ast)-body
Feb 26, 2003 09:05 AM
