question on gas lines and y-pipe
Old Dec 7, 2005 | 01:47 PM
lt1street's Avatar
Installed the headers and love them, They are pacesetters LT, NOw the y-pipe it look pretty easy but i seee a clearances problem between the group of fuel and brake lines on the driver side of the car. DOi need to relocate them over alittle but or will be fine with the way they are? Also,does anybody have some picture of the y-pipe installed i'd like to look at some before i start on may install. Thanxs for the replys!!!
Old Dec 7, 2005 | 02:31 PM
2000GTP's Avatar
Re: question on gas lines and y-pipe
The y-pipe itself didn't interfere at all with the brake/fuel lines. When I added a cat. on that side ,however, it got close to the brake lines so we had to gently bend the lines up a little bit.
Old Dec 7, 2005 | 04:50 PM
lt1street's Avatar
thank you
Old Dec 7, 2005 | 06:13 PM
95RagtopTA's Avatar
I wrapped mine with header tape--never can be too careful with fuel/brake lines .
Old Dec 7, 2005 | 06:18 PM
doug1105's Avatar
I stuck a piece of square galvanized sheet metal in between the floor and the header as a heat shield. I used self tapping screws to hold it up there.
No problems in a year and a half.
Old Dec 7, 2005 | 09:45 PM
firebirdStud's Avatar
interesting the way different people go about fixing lifes little dilemas! :-)
Old Dec 8, 2005 | 07:12 AM
The Engineer's Avatar
I also build a large custom driver's side heat shield using .030 sheet aluminum. You really need something to reflect the heat away from the fuel poly lines and brake lines on the driver's side. I have a pattern and some pictures of the aluminum heat shield. PM me if you want more info.
Old Dec 8, 2005 | 08:44 AM
Mean Green's Avatar
the brake lines should have any problem unless they are rubbing on the pipes. Fuel lines however are plastic and you don't want to risk those melting on the pipe.
Feffman
Oct 9, 2015 05:42 AM
Deadbolt24
Jan 19, 2015 01:29 PM
David Dorris
Jan 17, 2015 08:10 PM
blac94Z
Nov 28, 2014 01:53 PM
simple
Aug 11, 2002 11:56 AM
