question with fuel lines
Old Oct 26, 2004 | 07:03 PM
tonylittell's Avatar
i have a 94 z28
is there any solution to route the fuel lines that come out of the drivers fender well to the fuel rails with out them making a big uturn and then going from the front of the motor to the back?
im trying to clean up the engine compartment a little
thanks for the help guys
tony
Old Oct 26, 2004 | 07:41 PM
Re: question with fuel lines
ttt
Old Oct 26, 2004 | 07:50 PM
There are fittings that will allow you to attached braided S/S hoses to the hard lines. Then you could route them any way you want. My entire system is braided S/S lines, routed up from behind the engine. You might want to try a "search"... I know people have posted the manufacturer and part numbers for the fittings.
Old Oct 26, 2004 | 07:51 PM
MEAN LT1's Avatar
Not unless you want to do your own custome lines from the tank forward.
Old Oct 26, 2004 | 08:07 PM
i tried the search and couldnt find it under custom , fuel lines or custom fuel lines....not sure what else to search under
any other help would be appriciated fellas
Old Oct 27, 2004 | 07:15 PM
ttt
anyone else have a sugestion...or the part numbers for the adaptors i would need?
thanks
Old Oct 27, 2004 | 08:05 PM
n2ceptor's Avatar
http://web.camaross.com/forums/showthread.php?t=232104
This might help.... I know I have seen a post with pics, but I dont remember where.....
Old Oct 27, 2004 | 09:32 PM
captain_foustas's Avatar
my suggestion is you leave them as they are, recently i burnt a fuel line and im getting the braided type but im routing it the same way, i think the gm techs routed it that way for a reason, and if it deals with saftey i would rather not comprimise it.
Old Oct 28, 2004 | 04:52 AM
this isnt a street car and im not really worried about whe gm thinks is better/safer
it is a drag car...i just want to clean up the engine bay for looks and ease of getting to everything else
Old Oct 28, 2004 | 10:29 AM
Check the 2nd post in this thread for info and photos on compression fittings that attach AN lines to the stock hard lines at the rails.
http://web.camaross.com/forums/showt...l+line+fitting
If you are looking at something more permanent, there are people who have had -6AN and -8AN fittings welded to the back of the fuel rails to allow complete -AN systems. Just depends what you want to do, and how much you want to spend.
I wouldn't worry about the GM tech's logic.... I remember a website back a few years where a guy who had a fire in his 4th Gen LT1 engine bay was trying to put together a class action suit on the poor routing of the fuel lines.... seems the plastic ring holding the bundle to the throttle quadrent cover broke, dropped the bundle on the hot exhaust parts, the lines melted and his car went up in flames.
I run a -6AN supply line and a -6AN return line, both routed from the back of the engine down under the car. It's been running fine for 4 years, looks a lot better protected than the factory routing, and supports 800HP including dry nitrous.
HectorM52
Jul 30, 2017 11:46 AM
Deadbolt24
Jan 19, 2015 01:29 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
