Question on this engine set up seems to lack hp...
Old Jul 23, 2010 | 11:36 AM
  #16
Originally Posted by Final03
How we did the compression test was by pulling one plug out at a time... and checking the compression in each cylinder..and just bumped the ignition to til it indicated on the gauge for each cylinder we did. and with the headders trust me not an easy task.
That would explain the poor results - totally incorrect procedure. Per the above post, read what Shoebox has on his website.
Helpful hint - your engine is ovebored 0.030", not .30
Old Jul 23, 2010 | 01:23 PM
  #17
All opinions about your compression test results were based on the assumption you did it correctly. Might be time to redo it.
Old Jul 24, 2010 | 02:05 AM
  #18
Final03's Avatar
Here is what happened we found there was 3 wires that for some reason i think cuz of the headders were not snapped on all the way... and one brand new wire was broke so therefore i was running on 4 cylinders...
Finished putting it all together and actually my car has some power that i didn't know it had... Only thing is new exhuast goes on monday... And computer tune hopefully this week.... Only thing is the throttle has a slow response anyone know if this is where the computer tune will come in handy? Or is there something else possibly that is giving me the slow throttly response...
Old Jul 24, 2010 | 05:17 PM
  #19
96capricemgr's Avatar
Glad the problems were simpler but just for reference a properly running high mileage stock LT1 will still crank over 190psi, modified motors with higher static compression for NA power I would expect to crank even higher.
Old Jul 24, 2010 | 06:26 PM
  #20
Final03's Avatar
I;m going to have the shop look it over and tell me what all needs fixed on it so i have even more power before i get my tune done yet.
Old Jul 24, 2010 | 07:52 PM
  #21
The car wont run right without a tune so a cookie cutter parts replacing shop wont be able to help. You will just confuse them.
Old Jul 25, 2010 | 11:39 AM
  #22
Final03's Avatar
The shop i take mine to is the place that will do the tune as well...The guy owns the shop has raced for mcdonalds for like 10 years atleast. He also built my last engine....
Old Jul 25, 2010 | 12:08 PM
  #23
brucer's Avatar
your sig says your running 42lb injectors? is that a typo? dunno if they can be tuned down or whatever, but that sure is alot of injector for your setup..
Old Jul 25, 2010 | 01:09 PM
  #24
Running a racecar does not mean knowledgable about LT1s. I had a guy involved in ProStock tell me you can't ruin anything tighter than a 112LSA in an LT1 because the computer couldn't handle the overlap. It didn't matter atall to him that a LOT of us do this without any issue. He was involved in ProStock and "knew" more.
I hope your guy is good, just saying knowledgale in one area often leads to missplaced confidence in other areas.
Old Jul 25, 2010 | 05:55 PM
  #25
Final03's Avatar
He seems to know what he is talking about ran a shop for 16 plus years he builds his own race cars and works on tons of engines for people around this area...
I do have a new problem my transmission just started today not shifting into 3rd gear no clue why it was working flawlessly before any ideas of what that might have happened now?
Old Jul 25, 2010 | 05:56 PM
  #26
Final03's Avatar
Nope thats not a typo the guy i bought it off of put 42lb injectors on it lol... Way before i bought it.
Old Jul 25, 2010 | 07:20 PM
  #27
Is it trying to shift and just free wheeling or is it staying positively in second??
Old Jul 25, 2010 | 09:42 PM
  #28
Final03's Avatar
It shifts but its like its not going into gear...once it shifts into third gear i mise well be in neutral cuz thats what it feels like and it will free rev.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
hotrodyou1
Dec 20, 2014 10:05 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
CaRParts102
Dec 6, 2014 08:45 AM
