Question on cloyes double roller
Old Feb 12, 2004 | 02:04 PM
NAZTLT1's Avatar
Which mark do I use to line it up and which piston will be tdc? Right now I have the cam sprocket at 6 o'clock. At 12 o'clock on the crank which mark do I use? Triangle, circle or square?
Old Feb 12, 2004 | 02:20 PM
IDOXLR8's Avatar
It gets marked up with the circle.
Old Feb 12, 2004 | 02:52 PM
NAZTLT1's Avatar
Thanks. Okay I lined them up dot to dot, dowel pin is at 3 o'clock is that right. Should i even worry about where the pistons are at? 5 and 8 are near but not at tdc.
Old Feb 12, 2004 | 03:36 PM
NAZTLT1's Avatar
Got it!! Had the crank sprocket on the wrong keyway(retard)
Now its straight up (0) and 1 and 6 are tdc.
Old Feb 12, 2004 | 05:03 PM
LOL! Too many choices.
nikolt1
Feb 27, 2015 09:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
SABLT194
Aug 21, 2002 07:45 PM
IDOXLR8
Aug 6, 2002 12:30 PM
SABLT194
Aug 3, 2002 09:33 AM
