Question on cam/heads install.
Old Jan 28, 2003 | 01:32 PM
Red95Formula's Avatar
Question Question on cam/heads install.
I am planning on installing a CC306 w/ stage 2 heads. The first question is what kind of oil would you guys use to break this in? I normally use Mobil 1 10W30 but I am not sure what to use to break it in with. Also, I have read somewhere that you are suppose to soak new lifters in oil before the install is that true? Thanks for the answers and anymore tips that you can think of to make this go smooth are appreciated.
Thanks,
Chad
Old Jan 28, 2003 | 03:01 PM
Any suggestions?
Old Jan 28, 2003 | 03:09 PM
joeSS97's Avatar
Hydraulic rollers dont require a break in.Your valves and spring do thou.Just use what you normally would and chane it after a good drive.As for the lifters,yes soak em.Good luck with your new 'monster'.
Old Jan 28, 2003 | 03:11 PM
joeSS97's Avatar
Talking
Just saw that you use synthetic,dont use that expesive stuff at first.
Old Jan 28, 2003 | 04:08 PM
Thanks, how long should I soak them I plan on getting the oil tomorrow? I am guessing that 3 days is enough time for them to soak.
Chad
Old Jan 28, 2003 | 04:19 PM
BigBoySlim's Avatar
Just use some regular dino oil for anout 400-500 miles then switch back to Mobile1 with new filter. A good over night soaking will do.
Old Jan 28, 2003 | 04:24 PM
Cool, sounds good just waiting on the weekend now!
grabbem88
Feb 22, 2015 11:16 AM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
thenewkid
Nov 18, 2014 12:57 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
Black Sunshine/ 00SS
Aug 25, 2002 01:11 PM
