question about take motor out the bottom
Old Aug 11, 2004 | 11:18 AM
93transam1234's Avatar
I have read a few R&R guides and have a few questions
once i have every thing disconected what bolts drop the engine and where are they located
and after i have the engine down what else needs to be done to swap in a diffrent motor, i guess just mounts?
Old Aug 11, 2004 | 11:52 AM
94z'sson's Avatar
Re: question about take motor out the bottom
you need to disconnect the brake lines and set the ecm on top of the motor then you need to take the trans xmember and driveshaft and torque arm out then you need to get a big *** sturdy table and lower it til the kmember is sitting on it
there are 6 bolts that hold the kmember to the body undo them and undo the upper shock mounts(on inner fender wheel) and raise the car back up
then there are 2 motor mount bolts(1 on each side) they are the only thing holding the engine to the kmember and you cant miss them undo that and then lift the motor and trans off the kmember with a cherry picker(engine lift)
and install is just the reversal of beginning
Old Aug 17, 2004 | 07:37 AM
where exactly are the 6 bolts holding the k-member to the frame?
I look quickly last night and didnt see them, Do i have to unbolt them from the top or the bottom?
Old Aug 17, 2004 | 07:42 AM
They are on the bottom and pretty plain to see. Just look for the large bolt heads where the k-member meets the body. The middle one is up inside a recessed hole.
Old Aug 17, 2004 | 07:51 AM
crAzy95z28's Avatar
you can get those floor rollers ( things you lay on) get like 2 or 3 of them and drop the engine and trans on those,then get a engine hoist and strap the hoist to the car's frame and lift the car up and then jsut slide the engine and tranny out from under the car!!! then you can take it apart piece by piece, or have the hoist hooked up to the egine and be a bit easier to move around!
thats how i did mine and it was me and someone else...prety easy after those bolts are out!
Randy
Old Aug 17, 2004 | 08:26 AM
383Z4ME's Avatar
http://www.michiganspeed.com/enginepull/index.html
This does have pictures but none show those bolts. They are easy to find
D1SC383LT4
Jan 1, 2016 01:56 PM
sscott
Jan 17, 2015 04:30 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
formula218
Dec 2, 2014 04:27 PM
