A question about stock water pump configurations
Old Jan 4, 2006 | 05:50 PM
thesoundandthefury's Avatar
On almost every classic hot rod project I've seen where the owner did an LT1 swap, it seems like most of them had eliminated the 3 smaller pipes on the water pump. (The ones that aren't the main water inlet and water neck return.) I did a little checking on this and it seems that the early stock Corvette water pumps only had ONE of these extra pipes on it.
Early Corvette pump:
http://us.a1.yahoofs.com/users/42548...ARHvDBTNCERsZT
Camaro/Firebird pump:
I'm looking for ways to clean up my engine bay a little more, and I'm trying to determine what these extra pipes supply water to and if I were to eliminate the hoses and cap them off what I'd be "sacrificing." Has anyone ever blocked off these three extra pipes and just ran a bare bones water pump, and if so, what issues did you have to deal with as a result of doing so?
Thanks in advance for any feedback.
Old Jan 4, 2006 | 06:25 PM
OBE1 95Z28's Avatar
Re: A question about stock water pump configurations
One feeds the oil cooler, the other 2 feed the heater core.
Old Jan 4, 2006 | 06:41 PM
Obviously, it would be easier to see if one of the pics was not upside down , but you don't need any of the small pipes if you don't want to feed the things they go to.
Old Jan 4, 2006 | 07:14 PM
I copied the link to that pic directly off of an Ebay auction, and that's how the pic was situated there. (Couldn't find any other closeup pics of a Vette water pump anywhere else.) But since you're an extra special guy Shoebox, I went to the trouble of putting it right side up just for you.
Old Jan 4, 2006 | 08:51 PM
...extra special...
You could always look at pics on my site.
That 'vette pump pic you had showed less pipes than the pic I have.
Old Jan 5, 2006 | 01:13 AM
smoknta's Avatar
When removing the heater core, should the lines off the pump be looped together, or can they just be capped off?
Old Jan 5, 2006 | 07:35 AM
LJ93Z28GM's Avatar
I machined up some alum plugs and just set them in place no problems they were a press fit.
You can also rotate the tubes that come out of the pump if they are at a bad angle.
Originally I just blocked the cooler one off but then did all of them.
Old Jan 5, 2006 | 08:23 AM
smoknta's Avatar
So it wont hurt just to plug them off? I really rather not loop them, just for looks.
Old Jan 5, 2006 | 12:37 PM
Mtrhds94Z's Avatar
You can loop or cap them...
A lot of people use the Y or B body pumps in LT1 swaps due to there being no 'bypass hose' fitting..
Old Jan 5, 2006 | 07:25 PM
smoknta's Avatar
Guess I'll try and make some sort of cap. Anyone have any suggestions? I guess I could try and machine some plugs out of aluminum.
Old Jan 5, 2006 | 07:33 PM
LJ93Z28GM's Avatar
That is what I did no problems at all.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
