A question about stock water pump configurations
On almost every classic hot rod project I've seen where the owner did an LT1 swap, it seems like most of them had eliminated the 3 smaller pipes on the water pump. (The ones that aren't the main water inlet and water neck return.) I did a little checking on this and it seems that the early stock Corvette water pumps only had ONE of these extra pipes on it.
Early Corvette pump:
http://us.a1.yahoofs.com/users/42548...ARHvDBTNCERsZT
Camaro/Firebird pump:
I'm looking for ways to clean up my engine bay a little more, and I'm trying to determine what these extra pipes supply water to and if I were to eliminate the hoses and cap them off what I'd be "sacrificing." Has anyone ever blocked off these three extra pipes and just ran a bare bones water pump, and if so, what issues did you have to deal with as a result of doing so?
Thanks in advance for any feedback.
Re: A question about stock water pump configurations
Obviously, it would be easier to see if one of the pics was not upside down
, but you don't need any of the small pipes if you don't want to feed the things they go to.
I machined up some alum plugs and just set them in place no problems they were a press fit.
You can also rotate the tubes that come out of the pump if they are at a bad angle.
Originally I just blocked the cooler one off but then did all of them.
...extra special...
