question about stock oil pump
Old Feb 10, 2005 | 03:22 PM
slverbullet's Avatar
How reliable are the stock oil pumps on these motors? Ive got the engine pulled out, waiting for my h/c and was wondering if I should go ahead and replace my 128k mile oil pump. I'm thinking I probably should for good measure. If so, any recommendations on where I can pick one up at for a good price? thanks.
dave
Old Feb 10, 2005 | 03:26 PM
indieaz's Avatar
Re: question about stock oil pump
Being a mechanical part there isn't much that can go wrong. Unless you run the pan dry it will always be properly lubricated - but if you runt he pan dry you have other problems than a screwed up oil pump. About the only thing that can realistically go wrong is the pickup falling off the oil pump and that is very rare. I personally wouldn't bother with it, but if you have the engine allt he way out allready there wouldn't really be any harm in swapping it out.
Old Feb 10, 2005 | 04:15 PM
I would ALWAYS replace the oil pump if the engine was torn down. They wear just like anything else in the engine. It just does not make sense not to replace a 128k miles pump.
Part numbers for stock 3/4" pump, pickup and higher pressure spring listed below.
oil pump 3/4" inlet 12555283
oil pump screen 3/4" tube 12550042
white oil pump spring 3848911
These are from my part numbers page. Where to buy your GM parts is listed on my Tech Page.
Old Feb 10, 2005 | 04:41 PM
NOMAD's Avatar
Yep, NEVER rebuild or even tear down to inspect and engine without replacing the pump.
-Shannon
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
