Question about stock exhaust and headers.
I purchased some hooker headers that are going to be going on my car when I get the engine dropped in. However, I want to remove the piping that goes into the stock manifolds(stock manifolds are already removed). Where should I cut the exhaust off at? Before the Cat or after? I wouldnt mind sticking with the cat if it will route correctly with my LT hooker headers on. If it wont fit with the cat in the stock location, then I would rather just get a custom Y Pipe. I have to cut the exhaust due to the fact that it is all welded together.
Re: Question about stock exhaust and headers.
Currently I dont have a Y Pipe. I basically removed my old LT1 engine, rebuilt it, and now its done and I am looking to put it back in the engine bay. However, I will be replacing the old exhaust manifolds with my new hooker LT headers. So I was wondering where to cut off my exhaust that enters the engine bay to make room for my new headers and Y pipe. Do I cut the exhaust off after the Cat or before the Cat.
Also,
I cant seem to find the oil pump drive gear bolt. Can someone tell me the size of this bolt?
http://shbox.com/ci/oil_pump_drive.jpg
If you look at the picture above, its number 66 in that diagram. I have so many bolts and I cant find the one I need.
Also,
If you have stock exhaust, just cut it right before the cat if you still want to be street legal, then just weld your new y-pipe from the lt's to the cat. Just keep mind, the tighter the angles you have in your piping, the less flow you get.
Jan 5, 2015 07:14 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
