Question About A Sheetmetal Inatke Or Custumize A Holley Stealth Ram>>>
Old Feb 11, 2007 | 02:22 PM
Justin96'WS6's Avatar
CAN YOU PUT THIS HOLLEY STEALTH RAM INTAKE ON AN LT1 CAR? AND IS IT ANYMORE BENEFITIAL OVER MY STOCK 58MM BORED INTAKE. I DO HAVE AN 8LBS BLOWER SOON TO BE 18 TO 20 LBS!
ALSO LOOKING INTO GETTING A SHEETMETAL ONE BUILT FOR AROUND 1,000 AND THEN BOLTING A 90MM FAST LS1 THROTTLE BODY TO IT WITH CUSTOM MOUNT FOR THROTTLE BRACKET AND NO EMSSIONS OR EGR??
WHAT DO YOU THINK>>
HERE IS THE EBAY STEALTH
http://cgi.ebay.com/ebaymotors/Polis...spagenameZWDVW
Old Feb 11, 2007 | 02:31 PM
AZ2ENVY's Avatar
Holy caps lock batman
Old Feb 11, 2007 | 02:33 PM
AZ2ENVY's Avatar
It wouldnt fit on an LT1 without quite extensive mods . Even
then i doubt it .
Old Feb 11, 2007 | 02:55 PM
bdc95ta's Avatar
It can and has been done. Extensive modification yes, but it can be done.
-b
Old Feb 11, 2007 | 03:01 PM
1BadZ95's Avatar
It can be done...
Old Feb 11, 2007 | 03:50 PM
Kory 88 Iroc Lt-1's Avatar
I've got one that I'm going to be getting rid of in the near future. It has been converted to run on an lt1. It's currently on my car. It is rough and I would need to do some work on it before it would be ready to sell , but if you aren't in a hurry We might be able to work something out.
Kory
Old Feb 11, 2007 | 06:05 PM
luckyou03's Avatar
If i remember right you have to cut and weld the back of the intake to fit under the firewall area.
Old Feb 11, 2007 | 11:38 PM
Buddy of mine made 1,125HP with 20# boost through a stock LT4 intake manifold. You could do just as well with an LT1 if you had the heads to support it.
Old Feb 11, 2007 | 11:41 PM
mdacton's Avatar
that steath ram is smoke and mirors....great upgade for TPI but IMO wont touch LT1 style intake
Old Feb 12, 2007 | 07:49 PM
THIS IS THE INTAKE IAM PICKING UP FOR 900.00, GIVE ME YOUR INPUT IF IT IS DUMB AND WHAT WILL NEED TO BE DONE TO MAKE IT WORK WITH THE HIGH HP BLOWER APPLICATION. THAT NOS WILL BE PLUGGED. IT HAS A FUEL RAIL ALREADY SETUP BUT I GUESS I WILL NEED SOME AEROMTIVE AN FITTINGS AND A REMOTE ADJ FUEL PRESSURE REGULATOR. THANKS FOR YOUR FEEDBACK, OR SHOULD I SAY SCREW IT AND KEEP THE LT1 PORTED INTAKE WITH HOLLEY LT1 THROTTLE BODY
Old Feb 12, 2007 | 08:38 PM
T/A KID's Avatar
Buddy of mine ran 10.60's with a 383 SR with a Stealth Ram and a Monoblade. 6inch runners seem to help area under the curve, making nice TQ production and probably better HP than a LTx intake manifold.
With a Boosted motor, your ramming the air into the intake, from what I hear Runner length doesn't matter. Building a 383 with a D1SC and AFR heads and I sold the single plane for a LT4 intake.
Old Feb 12, 2007 | 08:59 PM
LiENUS's Avatar
Keep the LT1 ported intake with holley LT1 throttle body, the lt1 intake is remarkably well designed, unless you want to abandon the lt1 heads and use 18 degree heads or something there are no sane reasons to abandon the lt1 intake.
Potent77
Mar 16, 2022 12:13 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
