Question about racetronix fuel system install
Old Aug 17, 2004 | 08:52 AM
dkeers's Avatar
I just installed the racetronix lt1 fuel system (walbro pump and plug and play harness). It is very nice and easy to install kit.
Since I have installed the kit, my fuel pressure has been roughlly 2-3 psi higher than with the stock pump. I still have the stock FPR. Do I need to get an AFPR to turn it back to 43.5 psi @ WOT? I think I run a little rich @ WOT already and this will probably make it worse. Why won't the stock fpr keep the pressure the same as it did befere?
Dustin
Old Aug 17, 2004 | 08:54 AM
Don 97 SS's Avatar
Re: Question about racetronix fuel system install
Dustin
Your new pump produces a higher volume of fuel.
Old Aug 17, 2004 | 12:13 PM
dkeers's Avatar
I know it produces more volume, but the pressure relief valve in the fpr should still open at the same pressure right? With a higher volume pump you should just have a higher volume flowing back to the tank. I don't understand why the pressure would increase unless the return system is incapable of flowing enough fuel back to the tank.
Does this happen to everyone that installs this pump?
Dustin
Old Aug 17, 2004 | 12:19 PM
Ponyhntr's Avatar
When I did my install, my fp did not go up. But I have an ACCEL afpr, so I don't know if that would change things. It shouldn't.
Old Aug 17, 2004 | 01:00 PM
Racetronix's Avatar
Dustin
The factory regulator is not 100%. Most regulators will allow a small pressure rise with a substantial increase in fuel volume.
Old Aug 17, 2004 | 01:02 PM
GREGG 97Z's Avatar
Dustin
Stock FPR's wear out too. How many miles are on it? I ended up replacing my FPR with a new stock one when I did my Racetronix pump install last year. If the spring and seal in the stock FPR are worn it can allow to much fuel pressure to pass through.
Old Aug 17, 2004 | 06:42 PM
Spinner's Avatar
What he said. Same concept as a torque converter. Double the power, and it'll stall a little bit higher.
Double the fuel, and it'll allow a small pressure increase
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Jul 4, 2005 05:00 PM
Chrisdude
Jul 24, 2002 02:25 PM
