Question about the Opti Vac. line.
Old Apr 24, 2005 | 09:19 PM
sean1997ws6's Avatar
OK, on the vac. line that runs from the manifold to the opti there is a little blue and white disk. what is this things function? Mine got burned on the header and now I just have a straight line. my car feels weak up top and misses ever now and then. i get a vac./maf code ever now and then.can this effect my timing?
Old Apr 24, 2005 | 09:21 PM
94zgreenmachine's Avatar
Re: Question about the Opti Vac. line.
I believe it is a check valve so flow only goes one way. Not sure if it could affect the opti but it is there for a reason
Old Apr 24, 2005 | 09:23 PM
ibanez6rg's Avatar
May also prevent moisture from getting into the opti.
Old Apr 24, 2005 | 10:49 PM
Opti vacuum hose
Old Apr 25, 2005 | 04:20 PM
hey shoebox. do you anywhere that I can Buy that entire line and the parts?by the way will it have an effect on your car if the flow reducer and the backflow prevention things arent on there??
Thanks,Sean
Old Apr 25, 2005 | 09:22 PM
You can damage the opti without the flow reducer. The part number for the complete opti harness will all those things on it is listed on my part numbers page.
Old Apr 26, 2005 | 12:53 AM
is this all I would need?
1995-1997 optispark vent & vacuum harness 12555323 $11.58
1995-1997 optispark o-ring (need 2) 10474278 $0.76
Old Apr 26, 2005 | 04:35 AM
Spinner's Avatar
Dont need the o-rings, they're for the opti shaft
Old Apr 26, 2005 | 07:57 PM
can it mess with the timing if there is no flow reducer or backflow things?can it somehow effect the opti
Old Apr 26, 2005 | 09:03 PM
Fastbird93's Avatar
If you don't use the flow reducer you could possibly put too much vacuum on the opti internals. Use your imagination after that.
Old Apr 26, 2005 | 09:27 PM
so this part number here includes the flowreducer and backflow thing in it?
Sergio
Jan 27, 2016 04:27 PM
mikey4play
Mar 15, 2015 11:45 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
