Question about my computer
Old Mar 5, 2003 | 08:53 PM
john96ws6's Avatar
My battery died and my car wont start. I have been told that I need to have my computer "flashed" because it lost its memory. Alocal auto parts store just got a machine to do this, but you have to take the computer out in order to use it. I was wondering if there are any precautions in doing so or do you just unbolt and disconnect the harnesses?
Old Mar 5, 2003 | 08:55 PM
RamAir95TA's Avatar
Your PCM will reset itself. No worries about that.
Is your battery totally dead? Is it turning over?
Old Mar 5, 2003 | 08:58 PM
john96ws6's Avatar
Are you serious?!?!
I have been dealing with this for a couple weeks now. Trying to bring it out for spring. I have battery power and the starter cranks it just won't fire.
Old Mar 5, 2003 | 08:59 PM
john96ws6's Avatar
BTW Battery was fully recharged
Old Mar 5, 2003 | 09:09 PM
turbo_Z's Avatar
your computer is fine. the only thing that gets erased is the "learned" memory but basic program is still there.
look for a burnt fuse. if none then look below...
check for spark and check for fuel. depress the shrader valve to see if fuel squirts out and listen for humming from the pump. if you have those then pull the wire off the coil and see if you have spark from the opti. if that passes then put the wire back on the coil and check a plug wire to see if its firing. check that stuff out and then come back.
Old Mar 5, 2003 | 09:20 PM
john96ws6's Avatar
These are the things I have checked:
Fuel pump hums.
Fuses are all okay.
It is hard to work on because it is far away and in a "high class" condominium parking garage that doesnt allow teenagers to work on their cars. So I have to do work on it secretly. That really sucks that it isnt the computer. 3 people told me it was.
(gawd I dont want to have to tow it)
IgorT.455/406
Mar 12, 2015 03:39 AM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
cmdeshon
Dec 27, 2014 10:06 AM
