Question about LT headers?
It's usually good to review the parts and processes that are consumed/executed when installing LTs. The information may prove useful to you and answer some questions... a thread for you: http://web.camaross.com/forums/showt...hreadid=186318
Unless you get Jet-Hots LTs with emmisions junk on it, your EGR and AIR have to go but I'm sure you knew that. Cats will be pushed back, or you can just not run them like some of us without emissions testing do if you dont have it either. More than likely you will need to jack up the engine at least on the pass. side. Also you should go with over the valve cover wires for ease of installation and maintenence, but you can always route the wires in the stock location without any problems. With OVC wires, you will need a universal set that you cut and crimp yourself which is very easy to do.
