Question about the intake.
Old May 20, 2005 | 06:18 PM
desertfox's Avatar
I just got a new lt1 intake for my z28, and also a set of stainless steel bolts for the engine. So my question is, do I have to use some sealing material on the bolts,when I will do install my intake on the engine, or on any of those "big" bolts (looks some kind of plugs) what goes inside of the intake?
Thanks.
Old May 20, 2005 | 10:16 PM
OBE1 95Z28's Avatar
Re: Question about the intake.
The "plugs" on the side of the intake are vacuum barbs (used to attach your vacuum lines - brake booster, EGR, etc); use teflon sealer to install those. No sealant necessary for the bolts that hold the intake to the heads.
Old May 20, 2005 | 11:21 PM
I do use sealant on the intake bolts as most of the bolts are exposed to oil in the valve cover area. The sealant keeps oil from migrating up the threads.
Old May 21, 2005 | 10:47 AM
desertfox's Avatar
Thanks.
99TransAmWS6
Mar 22, 2015 11:00 PM
jj_burchiel
Mar 5, 2015 07:05 AM
pimpss96
Feb 12, 2015 01:28 PM
Noenav
Dec 6, 2014 07:35 PM
dansam
Jul 20, 2002 01:10 PM
