Question about Holley AFPR??
Ho many people with LT1s are using them? and how many defective ones have people run accross??
I am pretty sure that mine is defective because when trying t o adjust the FP the gauge stays pegged and dosent move off of 82-83psi even when the screw was on the lowest press setting.
Re: Question about Holley AFPR??
That's really wierd. I have to tighten mine to get the pressure to go up, are you going the right way?
Mine may or may not be defective, my pressure drops when the pump isn't running, but I haven't looked into it enough to blame the regulator.
So I am doing it right its just that the regulator doesnt seem to be doing its job.
worst reg ever.
