question about going from 1.5 to 1.6 RR
Old Apr 3, 2006 | 04:03 PM
97SS0594's Avatar
do i need to change my pushrods? i have 1.5RR in the car now, and i have 1.6RR to put in, will this change my lift geometry enough that i would have to go to a longer pushrod?
Old Apr 3, 2006 | 04:07 PM
BlackScreaminMachine's Avatar
Re: question about going from 1.5 to 1.6 RR
a pushrod length checker is the proper way to do it, but I used 7.200" pushrod on stock lifters for both.
Old Apr 3, 2006 | 04:20 PM
WS Sick's Avatar
I would say you'd be fine with the stockers.
Old Apr 3, 2006 | 05:47 PM
Jazsun's Avatar
I used the stockers, the hot cam kit which includes 1.6 RR's is made for hte LT1 and doesnt include them, so GM must not think you need them either.
Old Apr 3, 2006 | 07:20 PM
Bud M's Avatar
I used the stock pushrods with my Pro Mags. On later year LT1s you can use the stockers if you are using self aligning rockers. With guideplates you will need hardened pushrods.
Old Apr 4, 2006 | 09:50 AM
OBE1 95Z28's Avatar
If you're still running stock valve springs, I would consider replacing the springs to prevent coil bind with the larger rocker ratio.
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Rbain
Sep 4, 2002 12:35 PM
sseeya
Aug 8, 2002 11:37 AM
