Question about the flanges on Pacesetter LT's....
Old Jul 5, 2006 | 05:31 PM
KillerTA's Avatar
I have 2 sets of Pacesetter LT's and the flanges on both are not quite straight.
One set is about 1/8" high in the middle of the flange
One set is about 1/8" low in the middle
Should I worry about this or is this normal? I don't want to have to do this install twice!
They came with copper gaskets too.
Old Jul 5, 2006 | 05:56 PM
JoeliusZ28's Avatar
Re: Question about the flanges on Pacesetter LT's....
both of mine were about an 1/8" off on both sides, dont remember where though... they bolted up fine, and sealed. been leak free since installed a month ago.
Old Jul 5, 2006 | 10:08 PM
sam pace's Avatar
if you are worried about it. take them to a machine shop and have the cut them straight.
Old Jul 5, 2006 | 11:45 PM
KillerTA's Avatar
what do you think that would cost? One of my goals was to keep this as cheap as possible which is why i went with pacesetter.
Old Jul 6, 2006 | 05:18 AM
sssalah's Avatar
Bolt them up as they are. I haven't seen any header that would align perfect, the dimentions on the cars are not perfect anyways.
Old Jul 6, 2006 | 11:17 PM
sam pace's Avatar
It will be alot cheaper than bleeding knuckles and blown header gaskets.
Don't forget these cars are a BASTARD to put headers on, so take a little extra time and make sure your flanges are flat and spend a little extra money on your gaskets like Percy's seal for good gaskets.
A LITTLE EXTRA will save you alot later!
Old Jul 10, 2006 | 05:31 PM
atljar's Avatar
Mine were the same way. I took a BIG belt sander and just sanded them a touch so they were flush all across. It looked much further off than what they actually were.
WildRidez
Mar 27, 2015 08:22 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
alex5366
Feb 17, 2015 09:07 AM
LT14LIFE
Feb 9, 2015 09:35 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
