Question about egr blockoff.
Old Jul 27, 2004 | 08:39 PM
sean1997ws6's Avatar
OK heres the thing. When installing my new engine i got the EGR block off kit and put it on and now I have this problem where my car feels sluggish and has a rough idle(Rougher than the cc305 should),and surges hard just letting first gear take the car on idle.Sometimes the car will be pulling high RPM and then drop off and then pick back up again. I was wondering if there was anything that needed to be done along with just installing the plates.Also wondering if it could be a bad IAC.Also I cant let the clutch out slowly in first and let the idle carry it(car shutters hard and will stall).checked all the plugs,coil,and vaccum lines and blocked off the old EGR vac. hose.I am at a loss here.
Thanks,Sean
Old Jul 27, 2004 | 08:45 PM
wicked_95z's Avatar
Re: Question about egr blockoff.
If its not miss firing, when was the last time you changed the opti
Old Jul 27, 2004 | 08:47 PM
been about 80k, I have a new one sitting in my trunk about to instal it friday.Any idea how much the CAP AND ROTOR PART cost? You think that could be it?
Old Jul 28, 2004 | 06:23 PM
wicked_95z's Avatar
My car was having the same rpm dropoffs and I took apart my opti to clean it and found the shutter wheel was loose and throwing the timing off
Old Jul 28, 2004 | 07:13 PM
Wicked z , replacing the opti this week. Semper fi. I am with you at good old camp lejeune.
Old Jul 28, 2004 | 09:18 PM
wicked_95z's Avatar
No s#@t. You know we have a car club in J-ville right? What does you car look like I may have seen you on base. I work at Maint BN. in French Creek
Old Jul 29, 2004 | 04:55 AM
Dark Green WS6.I work at thr Brig. I think isaw you all accross from Navy Fed. Caris on my car domain link in sig.
Old Jul 29, 2004 | 05:18 AM
wicked_95z's Avatar
Yep every Sat night. You should stop by one weekend
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
