Question about cam vs. emissions
Old Feb 22, 2004 | 09:23 PM
Mitch96TA's Avatar
I'm getting ready to build a forged bottom end 383 with a P1SC supercharger.
I'm curious how big of a cam I can use and still pass the emissions sniffer test?
Is the cam going to be the biggest determining factor for emissions?
It's being converted to OBDI and will have ported heads. Does anyone know how far I can go before it won't pass?
I think the emissions requirements are similar to California.
Old Feb 22, 2004 | 09:26 PM
aintno6's Avatar
If its anything like IL. I would keep the OBD-II. Here in IL (my area), when you have an OBD-II car they hook it up to the computer. And look for trouble codes, thrown off by the PCM. If there are'nt any problems, then you pass. Now from 7?-95, they put you on the dyno/sniffer. And look test the exhaust to see if you fail their tests.
Hope this helps. I hope someone from your area can help you out.
Old Feb 22, 2004 | 10:05 PM
truedualws6's Avatar
That's not too bad. In CA they do both, plus run the
car on a dyno.
Old Feb 22, 2004 | 10:17 PM
lt1hatesme's Avatar
i remember having a few of my cars smogged and they never were on a dyno.
Old Feb 22, 2004 | 10:29 PM
Robs97Z28's Avatar
dyno testing started this year in CA. I was lucky enough to have smogged last year. Not looking forward to the new smog test myself. I'm interested to find out what cam I can run in CA.
Old Feb 22, 2004 | 10:40 PM
lt1hatesme's Avatar
guess i have to find a shady character to do a lil somethin under the table.
Old Feb 23, 2004 | 08:26 AM
Mitch96TA's Avatar
Here in Utah, some counties plug OBDII cars in and scan them for codes. Cars before that get run on a dyno and they use the sniffer.
Where I live they just use the sniffer on the dyno.
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
Queens94z28
Nov 20, 2014 06:03 PM
