Question about block prep.
Old Mar 1, 2008 | 10:08 PM
Dave1980's Avatar
Hey just torqued down my one of my head gaskets on my new shortblock today. I noticed that I forgot to clean the oil off of my deck surface before installation. I hope that this is not going to cause the gasket to leak or fail. Does anybody have any more info on this?
I noticed that it said in one of my books to clean with solvent before hand.
Old Mar 1, 2008 | 10:53 PM
Yes, it should have been perfectly clean of oil or contaminants. If too contaminated, it might not seal.
Old Mar 2, 2008 | 10:17 AM
Dave1980's Avatar
damn do you think i ruined my gaskets? I am just going to buy more I guess just to be safe. What a stupid error. One of the gaskets is not torqued, but has sat on the surface. I guess better to catch this problem now while engine is still on stand.
Old Mar 2, 2008 | 12:33 PM
SS MPSTR's Avatar
I'd take care of it just in case. $100 now or replace it later after everything is on the engine. What's your time worth?
Old Mar 2, 2008 | 12:41 PM
pizzi-man's Avatar
If you haven't run the motor yet and the heads have only been on for a short time then go ahead and reuse the head gaskets.
Old Mar 2, 2008 | 12:53 PM
If they are composite gaskets and are soaked with oil, I wouldn't.
Old Mar 2, 2008 | 02:09 PM
The_Bishop's Avatar
It's way easier and cheaper now to toss that gasket and replace it. Composite gaskets go on dry, and the mounting surfaces must be perfectly clean and oil-free.
If you don't, you're going to be doing it again, later, when it's in the car and a lot harder.
Old Mar 2, 2008 | 05:25 PM
Dave1980's Avatar
Yeah that is why I asked here. It was a 100 dollar screw up. I would much rather change them on the stand, then risk having them leak on the engine after the fact. It sucks but lesson learned here. I had oil on the block to protect it , just goofed and forgot to get it off.
Old Mar 2, 2008 | 06:52 PM
Yeah, sanitizing the mating surfaces is always the last thing you do before putting a gasket on.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
