Quench and this piston
Old Apr 3, 2006 | 01:49 PM
marshall93z's Avatar
I have had these pistons for a while and just got around to looking at them. Will the way the top is made be bad for good quench? Instead of it being a flat top with a dish, it has a beveled edge. By looking at it, you'd think some of the mixture would be trapped at the outside of the piston.
Thoughts?? Am I way off base here??
Old Apr 3, 2006 | 03:17 PM
GetaZforgetGT's Avatar
Re: Quench and this piston
What is your determining factor in deciding on that piston?
There are a ton of other options out there that may suit your needs and not have that particular design.
Quench is normally measured from the highest part of the piston...ie distance in the hole... + gasket thickness = X
I don't know if I've ever seen any special calculation for pistons with that design but I could be wrong.
Old Apr 3, 2006 | 03:43 PM
I have had them for a while.
Right, but when that piston comes to TDC the mixture in the dish is almost gonna be seperate from what is in the outer ring(or whatever).
Old Apr 3, 2006 | 06:44 PM
I don't disagree with with you on that but I don't know how much of a difference it would make.
Old Apr 3, 2006 | 10:56 PM
Just curious.
I'm sure someone who knows will chime in eventually!
Old Apr 6, 2006 | 12:35 PM
Maybe I should have put this in "Advanced Tech"?
Old Apr 6, 2006 | 12:43 PM
87lt1rx7's Avatar
I would put this in advanced. the brains at this forum love to look in their first i bet. I have never seen that psiton design before
Old Apr 6, 2006 | 02:45 PM
LiENUS's Avatar
I believe that is a non quench piston, you probably shouldnt be running it with a quench head. That is more meant for something like a hemi headed engine. If it's working for you now then dont tear down just to replace the pistonsm, but if you ever need new pistons I would avoid that style.
Old Apr 6, 2006 | 10:56 PM
I'm not running them yet. I bought them off of a friend a while back. Came out of a blower car making 600+ rwhp.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
