Quarter mile numbers for LE3 head 355's????
Old Apr 14, 2006 | 12:05 PM
12SCNDZ's Avatar
Just curious about if anyone has any solid numbers for a set of Lloyds heads on a 355. I've already got the bottom end built, and am looking into a set of heads from Lloyd. The motor is a 12:1, 6" rod, 847 cammed 355. The car is a 3200# '93Z with a 700, 3:73 gears, and Spohn suspension. I need a set of heads that will put me in the 11.2 -11.3 range (on motor). I'll shoot a 200 shot on top of that.
Thanks,
Frank
Old Apr 14, 2006 | 04:48 PM
12SCNDZ's Avatar
Re: Quarter mile numbers for LE3 head 355's????
WOW...Nobody has any times for Lloyds heads?
Frank
Old Apr 14, 2006 | 05:08 PM
Javier97Z28's Avatar
Moderator
My times aren't really worth posting yet, but with the LE2 I picked up about 5 mph over my old cam only setup in similar conditions. Not worth posting b/c that was my first shakedown run only 48 hours after completing the car, and rounding out a cam due to a possible loose rocker... also, the tranny was slipping 2-3 and not allowing the car to shift at the 6500 rpm shift point.
My new setup will be a 355 with LE2 heads, and an LE3 cam. I'm hoping to go for low 11's with this setup.
I need to contact you about a tranny first, probably in a few months once I get my car together, as my 2-3 is slipping bad at high RPM. Stock (cept for a transgo stage 2 and vigi 3200) 4L60E, 90k miles, tons of 1.6x 60' times, and tons of low 12 sec passes, and raped on the street constantly.
Old Apr 14, 2006 | 08:30 PM
12SCNDZ's Avatar
That's cool. Keep me in mind. Looking for something similar to what Matt has?
Frank
Old Apr 14, 2006 | 10:24 PM
Moderator
Frank
I'm looking for a pretty damn beefy 4L60E that will take what my car will throw at it all motor (low 11's) AND withstand nitrous launches in the future..., I think that would be your ProRace tranny right? Soo I guess I'm looking for a low 10 second tranny.
Have your prices come down a bit? They look lower than last I checked.
Don't worry, you are my #1 choice when it comes to where it's going to go, now orries.
Old Apr 14, 2006 | 11:17 PM
Szizzle's Avatar
Hughes makes a GREAT racing transmission. I personally think they are one of the best in the business. www.hughesperformance.com
The Chevelle in the link in my sig has a hughes transmission and it was opened up at 40000 miles and the guy who built it said it looked brand new. Fill out a tech card and talk to them.
Old Apr 15, 2006 | 01:15 AM
hvyss's Avatar
With going to LE2 heads and staying with the CC 503 I picked up .8 tenths of a second over Agistino ported Iron heads from 12.9's to 12.1's. This is in a 4400 lb Impala SS with a 355 bottom end.
HVY SS
Old Apr 15, 2006 | 02:40 AM
jimbob65's Avatar
Ellis went 11.85....LE2 heads, 12 bolt 3.73 gear, yank converter, 847cam.
Car weight was 3800lbs at the time, and the bottom end was out of a junkyard car. We just rolled some new bearings in it and ran it for two years at the strip and DD...
Now with a 12 to 1, 380 cubic inch, a liitle bigger cam, more porting to support high rpm in the 380. The car ran a 11.47 spinning the tires on the launch. 17's up front. Were hoping to see 11.2's now with a 150lb lighter combo including front drag tires and rims(still 3650 weight).
So, yes his heads work great........
Old Apr 15, 2006 | 04:36 AM
94FormulaFbird's Avatar
hah.... 12SCNDZ builds race transmissions, www.cahallperformancetransmissions.com
Hes even sponsors this board
Old Apr 20, 2006 | 10:34 AM
1SlowFormula's Avatar
Strange there aren't more posts with how the LE3 performs, I would think even on a 383 could help him get ideas of how it would act on his 355...
Old Apr 20, 2006 | 11:05 AM
LT4POWR's Avatar
I'd be looking more at dyno #s and trap speeds w/ specific motor mods. A 355ci LE3 could run anywhere from 14s to 10s. Quater miles times are highly dependant on track conditions, car setup, driver skill, etc.
LeftoverChinese
Jan 14, 2024 03:03 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
MadMav
Feb 6, 2015 11:02 PM
InfernalVortex
Jan 17, 2015 09:35 AM
