Quality GM Parts???
Old Jan 13, 2006 | 08:27 AM
OutsiderIROC-Z's Avatar
Quality GM Parts???
GM parts are a joke. I open up the new oil level sensor I ordered for my 95 Z, and the POS is made completely of plastic..... I am about 99% sure that the one on my car now is not, the fitting that screws into the pan looks to be copper. To spend $20 on this and receive such a pile of garbage just pisses me off.
Old Jan 13, 2006 | 08:33 AM
Javier97Z28's Avatar
Moderator
Re: Quality GM Parts???
I'm pretty sure the stock one is plastic too. So uh.. yah.
Old Jan 13, 2006 | 08:54 AM
shartflhs's Avatar
Do you have the part number for the oil level sensor? Mine is leaking and really should be replaced. Plastic or not i need to get one. And $20? I thought it was a bit more, where did you get it?
Old Jan 13, 2006 | 09:01 AM
So uh... yah, I'll post tonight when I take the one out of my car what it is made out of....
Old Jan 13, 2006 | 09:05 AM
The part number off Shoebox's site is 12579983, when I get a chance to go out to my car, I'll get the number off the box. It was listed on GM Parts Direct for around $12 with $10 or so for shipping. I got it from the local Cheverolet dealer for $20, and I had it in 2 days.
Old Jan 13, 2006 | 09:31 AM
Blownbird355's Avatar
Isn't it a low oil level sensor and not a oil level sensor?
Old Jan 13, 2006 | 10:20 AM
It is the sensor for the Low Oil light on the dash underneath the speedometer.
Old Jan 13, 2006 | 01:41 PM
96capricemgr's Avatar
Yeah stock is plastic and FEW have problems with it so maybe you should a little learning before ignorantly shooting off your mouth.
Old Jan 13, 2006 | 03:36 PM
Quickss96's Avatar
they are plastic i just broke mine.
Old Jan 13, 2006 | 07:12 PM
I don't think I shot my mouth off, and when I pulled mine out of my car tonight, it was metal, so maybe you should do a little learning before you shoot your mouth off.
If you don't like what it being said in a thread, don't read it.
Old Jan 13, 2006 | 07:59 PM
LJ93Z28GM's Avatar
My 93 has metal on the part that sits on the outside of the pan, the internal part that measure oil level is plastic.
Most break when people yank them out incorrectly or drop something on them. The part is not common for failure.
Part is plastic in my eyes but has a metal shell on the hex portion.
Old Jan 13, 2006 | 08:15 PM
rskrause's Avatar
Moderator
I hate to get in the middle of a cat fight. But I am willing to take that risk to point out that you can't really know if you will like, or dislike, a thread until you do read it
That is all.
Rich
Old Jan 13, 2006 | 08:39 PM
That is the way mine is, but the new one is ALL plastic.
Old Jan 13, 2006 | 08:40 PM
That is all.
Rich
You have a point Rich, but I didn't think I made an ignorant statement, but regardless, I'm done with him.
Old Jan 13, 2006 | 08:52 PM
LJ93Z28GM's Avatar
The metal than on your piece is like mine as you said looking at the piece ie is just a way to cut out an cost that is not needed. Based on the torque specs it is not needed. Even if it is there the thin sheet metal that is really is not doing much.
Both of you guys are correct, now thinking about it I have seen newer 4th gens that are all plastic.
If they were going to change something on the sensor it would be to allow the mechanic to easily remove the elctrical connector without having to use a tool.
