Q about timing chain for LE2 package.
Old Apr 25, 2006 | 10:46 AM
  #16
Javier97Z28's Avatar
Moderator
Re: Q about timing chain for LE2 package.
Originally Posted by scrmnws6
The reason I questioned your part number because it was not listed under the LT1 engine, but rather gen 1 etc.
So 3145 is NOT a double roller timing chain, but rather a single chain that is basically an OEM replacement timing chain set, right?
NOOOOOOOOOOOOOOOOOO
Part #3145 is THE DOUBLE ROLLER SET for use with an LT1, which requires:
Slight timing cover clearancing
Electric water pump
Sorry for the caps but I can't figure out how to clear it up anymore.
Old Apr 25, 2006 | 11:03 AM
  #17
scrmnws6's Avatar
Originally Posted by Javier97Z28
NOOOOOOOOOOOOOOOOOO
Electric water pump
Haha... thats fine. Sometimes I have to convince myself that my logic is correct.
You are going to have to pardon my ignorance when it comes to this. Its probably a good thing that I am not insatlling my LE2 kit myself.
So, part# 3145 includes the two sprockets and the double roller timing chain that I can use with my LT1. I think I got it now. Im sure Ill have a few more questions shortly.
Old Apr 25, 2006 | 11:24 AM
  #18
Moderator
You got it!
Old Apr 25, 2006 | 10:31 PM
  #19
97silvermaro's Avatar
i have the le3 heads le2 cam setup with the cloyes timing chain havent had a problem yet and ive been runnin it for a year
Old Jun 1, 2006 | 05:59 AM
  #20
93z383's Avatar
In reference to the water pump on this thread, One, do you delete the water pump drive gear, Two, is there a compadible timing cover without the water pump shaft hole that you can replace the stock with in order to avoid the welding/sealing, Three Are there any disadvantages to a removing the water pump gear if you indead have to do that? Thanks
Old Jun 1, 2006 | 06:00 AM
  #21
93z383's Avatar
NOOOOOOOOOOOOOOOOOO
Electric water pump
Old Jun 1, 2006 | 07:07 AM
  #22
Moderator
1) Yep, you have to!
2) Nope, just use a quarter and some quicksteel around it and it will seal up fine.
3) You have no choice but to remove the water pump gear when running a double roller. There's no downside whatsoever to removing it.
Old Jun 1, 2006 | 08:18 PM
  #23
93z383's Avatar
ok then, sounds like a plan, thanks for the help, alteast I convinently already have an electric water pump...
Old Jun 4, 2006 | 08:33 PM
  #24
TransAm396's Avatar
lol i used a stock chain..been holdin up great to serrrious abuse.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
