Q. about temp and door weather strip
Ok i just had a quick q that i really cant find too much info on.
1. Lately my car seems to run hotter then norm. It used to run around 180-185ish around the first line. Now it can go half way up the guage. I have a new radiator, electric pump, system has been bleed and has a 50/50 mix, bottle of water wetter,and pressure tested fine, no trash in front of the rad. , fans running fine it seems. Temp is about 40 around here now.
Now since it used to run around the first line i have changed from a hypertech to a custom tune from pcmforless and added ground effects and a rk sport air dam which is much bigger then stock and now it seems like it would get more air. Bryan setup the temps to run colder then the hypertech he said so that should be good. Any ideas what could be the cause? Recently it is actually running warmer since the low coolant sensor broke when my battery accidently smashed it but its replaced now. Ugh its such a pain with this car lol
2. Just wanted to know how the hell to get off the window rubber on the outside of the door? and also the triangle behind the glass near the door.
Thanks in advance!
Thanks in advance!
Re: Q. about temp and door weather strip
Should be. Replace the window adjuster/stabilizers while your in there. They're cheap.
Sills
10284222 RH
10284223 LH Outer Sills
16651944 RH
16651945 LH Inner Sills
10257988 Stabilizer (4 needed)
Sills
10284222 RH
16651944 RH
Originally Posted by shoebox
Here is the mounting for the mirror applique.
Originally Posted by Spinner
I think he's talking about the black plastic triangle sail panels, which have a weatherstrip looking piece on the bottom of them. ...
Yeah the rear ones... i already have taken the others apart. So the rear ones are like just double sided taped on or something ? No screws on the inside or anything? just pry em off and buy new ones or something? Hmm sounds interesting .....
May 21, 2015 01:04 PM
96z
Aug 2, 2002 09:00 PM
