Putting Long Tubes on a 93 LT1, Quick ?.
Old Mar 5, 2004 | 06:33 PM
Kris93/95Z28's Avatar
Do I need O2 extensions for Jet Hot Long Tubes? Or will the stock harness for the O2s reach?
Thanks!
Old Mar 5, 2004 | 06:48 PM
HoneyCombs's Avatar
I extended the stock wire myself, people recommended getting the heated o2's for the LT's but my car ran fine without them
matt
Old Mar 5, 2004 | 06:50 PM
Did you just splice in a wire?
What guage wire would you suggest I use If I decide to try this?
Old Mar 5, 2004 | 07:15 PM
PatriotTA's Avatar
Yeah, you can splice into the wire. A good rule of thumb is to use one guage large than the wire you are splicing into. Example - if you find that the O2 wires are 16g, use a 14g wire to splice into them. Remember to solder your connections and use shrink tubing to protect it. I have also heard that you should cut the stock harness, that goes from the ECM to the connector, and NOT the wires on the O2 itself? Why? I don't know, but I hear it a lot. Me? I bought O2 extensions, because I felt it would be cleaner, just MHO.
Old Mar 5, 2004 | 07:18 PM
Brent94Z's Avatar
Super Moderator
While 14 gauge might be better, 16 gauge works I spliced into my O2 sensor wires (not the factory wiring harness) on my 94Z with 14 gauge a couple years ago and so far so good. Also just did this last weekend on the 96SS and again, no problems.
I have Hooker Long tubes and spliced in 6" wires for one and 13" wires for the other.
Old Mar 5, 2004 | 07:20 PM
Spinner's Avatar
You'll either need extensions, or will have to splice. Stock wont reach
Old Mar 5, 2004 | 07:40 PM
revtime's Avatar
I too spliced the O2 sensors themselves, be damned if I am going to cut into the harness.
I used Bosch O2s and it has been all good so far.
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Queens94z28
Nov 20, 2014 06:03 PM
Jul 4, 2005 05:00 PM
