puttin in cam, dowel rod?
Re: puttin in cam, dowel rod?
If you did not have trouble with the old dowel pin, simply measure the length with a caliper and carefully tap the new one in until you achieve the same length. Be sure not to mushroom the end of the pin. Use a bras hammer or or hold something against the pin and tap on the object instead of the pin.
yes the new cam has shorter rod. your page is excellent shoebox, used it all this weekend. there is no way to get the dowel out without the shop? spent too much money already
