Put the mailorder tune in the car and went to the track last night...
Old Feb 18, 2006 | 04:43 PM
  #16
RedLT4Mike's Avatar
Re: Put the mailorder tune in the car and went to the track last night...
You cannot trust the readings of a narrow band O2 sensor @ WOT
Thats what widebands are for.
Old Feb 18, 2006 | 04:45 PM
  #17
'94 Bad A Z28's Avatar
I know that is why I said it's more of a "guestimation" gauge.
Old Feb 18, 2006 | 04:58 PM
  #18
Javier97Z28's Avatar
Moderator
Oh, thought you had LE3 heads from a previous post... n/m, those #'s aren't the ones I saw posted before...
Like I said before, a trip to the dyno is in order to see what the heck is goin' on. Did madz28 or pcmforless do your tune? As long as you got what you ordered I can't see it being too off.. I had a pcmforless tune in mine and ran 112.8 traps w/ it cam only.
Old Feb 18, 2006 | 06:12 PM
  #19
96capricemgr's Avatar
An AFPR can make the tuners job a lot more difficult unless you are very sure you have it set for the pressure he had in mind.
How good is the rebuild what was the target compression ratio?
MOST shops are unfamiliar with the LT1 and it's abnormally high compression ratios unless you truely enlighten them as to what stock is and convince them to go higher they will likely put it together for 9.xx:1 which would be a bad thing with that much cam. You didn't list a shop or any details so I am just guessing here. Had you used a vendor here that knew the LT1 I figure you probably would have mentioned that.
Old Feb 18, 2006 | 08:04 PM
  #20
My guy is a LTX/LSX specialist, he has a '98 Z28 him self. The compression ratio on this motor is near stock at 10.4:1... there was nothing special in mind with this motor, it was just to get the car up and running again.
Those numbers that you are thinking of are my buddies stage 3 LT1 heads, stock LT1 castings, I know which ones you are thinking about.
Old Feb 18, 2006 | 10:29 PM
  #21
Specialist or not did he know exactly what you are running for pressure? You could have the best tuner ever but if you have the FP set for other than what he figured for things will be wrong.
Old Feb 19, 2006 | 05:23 AM
  #22
The tuner tuned for stock FP and my car is running a little less than stock, but the car is still pig rich.
97SSdude
Dec 31, 2014 07:43 PM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
