pushrods for upper 6k rpm and solid cam
Old Mar 5, 2007 | 12:13 PM
lt4 fd's Avatar
I have an 94 with the hardened pushrods, do I need the chromoly or is that not needed. New hardened pushrods maybe? springs are comp cams 977-16's has ti retainers and stock valves.
Old Mar 5, 2007 | 01:03 PM
BUBBA's Avatar
I assume that you are installing/have installed larger RRs----if they are non-self aligning, then you will need hardended PRs to go along with your guides, but if you already have them, you should be good to go. On the other hand, if you are getting Ti retainers, you might as well make sure you have the hardened prs. JMHO
Old Mar 5, 2007 | 01:51 PM
speed_demon24's Avatar
I would definatly get chromoly pushrods, I've seen my friend bend regular hardened ones with a hydrolic roller, some of them actually broke in half from getting caught on parts when they bend and it wasn't from an over-rev, they just weren't strong enough.
Old Mar 6, 2007 | 10:09 PM
lt4 fd's Avatar
I was leaning towards chromoly because of the nature of the cam which my dumb *** left out the info on. I just wanted to be sure I wasnt wasting money. Its a 230/236 solid roller... high .5's lift.
Old Mar 7, 2007 | 01:33 AM
STREETLETHALZ's Avatar
sounds like expensive pushrods would be cheap insurance for a solid roller.
Old Mar 7, 2007 | 01:47 AM
SStrokerAce's Avatar
Yeah last place you want to skimp on pushrods is on a Solid Roller.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Feb 17, 2015 08:12 PM
