Are pushrods down when cylinder is at tdc?
Old Jul 28, 2003 | 07:28 PM
red95lt1's Avatar
I am setting my valves and was wondering when a cylinder is at tdc? Is it when both the pushrods are down or up?
Old Jul 28, 2003 | 07:34 PM
AsianSensation's Avatar
Down.
Old Jul 28, 2003 | 07:58 PM
Ai's Avatar
Ai
To adjust the valves, you simply need to have the lifter of whatever valve youre adjusting on the base circle of the camshaft. If you want to start on the #1 cylinder, then turn the engine over until the Exhaust begins to open. When you see that, adjust that cylinders INTAKE rocker to 1/2 turn past zero lash, and set your polylock to hold it there. Turn the engine over more, and watch the intake you just adjusted, begin to open. When that intake valve is beginning to CLOSE, that cylinders exhaust should be on the base circle, so you can adjust that one. It's not too tough
-Phil
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
94Maroz28
Oct 27, 2015 04:38 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
jayblev95
Sep 26, 2015 09:44 PM
