Pushrod question
Old Aug 6, 2007 | 09:38 AM
Fast4thGen's Avatar
Pushrod question
I had the machine shop that is rebuilding my shortblock measure for the pushrod length, they came up with 7.100. Ive done some searching on the board and that seems kinda short for what im running(but what do i know im clueless about this). I bought LE1 heads with larger valves and a LE1.2 cam off a board member here (he sold a set of 7.200 pushrods when he parted his setup) and am also using comp pro mags 1.6 and the impy head gasket and the block is stock height(piston is 30 in the hole). So what are your opinions does this sound right.
Also i dint think about it till now but since im sure the heads are milled and using the impy head gasket is that gonna cause me to have to get my intake machined to fit correctly?
Old Aug 6, 2007 | 10:46 AM
Z-RATED94's Avatar
Mine set-up is similar to yours. When mine was checked, it needed 7.150s. Unless you check it yourself, it looks like your going to have to trust your shop. You can trust them, right?
Old Aug 6, 2007 | 11:05 AM
arcticz28the383's Avatar
Only way to be absolutely sure is to check it yourself. Ask them to show you maybe when you go in there to be sure.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
alex5366
Feb 17, 2015 08:12 PM
Jul 4, 2005 05:00 PM
