pushrod length
Old Feb 13, 2015 | 10:06 PM
  #16
8cylinders>4's Avatar
Re: pushrod length
wouldn't a smaller base circle cam would require longer pushrods?
Old Feb 14, 2015 | 11:40 AM
  #17
Chimera96's Avatar
Re: pushrod length
Originally Posted by Chimera96
Maybe AI cuts smaller base circles or larger seeing as your PR check comes in at 7.050.
yes and larger base circle a shorter PR. other variables also contribute to PR length. Block & head milling and head gasket thickness
Old Feb 14, 2015 | 08:30 PM
  #18
97WS6SCharged's Avatar
Re: pushrod length
You generally use taller lifters. If you don't you run the risk of the lifters turning inside the bores and eating the cam up.
Old Feb 15, 2015 | 01:47 PM
  #19
MachinistOne's Avatar
Re: pushrod length
Having the narrowest sweep is more important than being perfectly centered over the valve tip.
I think you need to read over a few online tutorials on finding pushrod length and start over fresh because it doesn't make any sense that you should be using a 7" rod with that setup unless the lifter PR seat is higher than your old lifters...which with a GM LS7, it shouldn't be as that's the superceded part for all factory HR applications now.
Old Feb 15, 2015 | 02:40 PM
  #20
Chimera96's Avatar
Re: pushrod length
these are Delphi SBC lifters, many prefer over the LS7 ones
White Performance Detail Description
Old Feb 17, 2015 | 11:39 PM
  #21
chuyz28's Avatar
Re: pushrod length
OK guys been chatting with Rob I believe from shbox website and finally found the problem I was doing it wrong I was not at the base of the cam so I now know I will need longer pushrods thanks guys for all your help and thanks to shbox now just have check what length push rods the ones I have going to be to short
Old Feb 19, 2015 | 12:50 AM
  #22
Chimera96's Avatar
Re: pushrod length
yep, confirming you are on the base circle of cam is important
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
realistyc
Jul 28, 2015 07:32 PM
94Form
Jul 17, 2015 10:56 PM
