Pushrod Lengh Question
Old May 30, 2003 | 11:33 AM
Rico's Avatar
Do you have to change the pushrod length with the LT-1 when putting in a big cam? also does anyone know if with 7/16 studs guide plates etc, and the pro mag compcams non S.A rockers will bottom the tunion out on the stud with a bigger cam when trying to lash it down.
...Rich
Old May 30, 2003 | 11:49 AM
allmotorta's Avatar
I'm running the CC306 with my stock pushrods. I also had my heads milled .030 and used a .029 head gasket, and the pushrod length is still fine. I am also running 7/16 studs, GMPP guideplates, comp pro mag 1.6's, and had no problems
Old May 30, 2003 | 12:00 PM
jpolz's Avatar
I don't think he would be able to do all that with his. The length is fine...but 93 & 94 got hardened rods stock, 95+ didn't.
Old May 30, 2003 | 12:06 PM
allmotorta's Avatar
Woops, didn't catch that Yeah, definitely don't use your stock pushrods. A set of stock length (7.200") hardened pushrods costs $35ish, so its not a big deal
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
alex5366
Feb 17, 2015 08:12 PM
Jul 4, 2005 05:00 PM
