push rod lenght for afr 210
No-one can say definitely what size push rods would be needed. You have to measure for them. Once you have all the hardware assembled, you can use your original 7.2's to find out if you need longer or shorter. check out this page for information on how to measure. http://www.compcams.com/information/Products/Pushrods/
Once you find out if the new ones are longer or shorter than stock, then order a measuring rod and find the correct length according to the page listed above.
Don't assume anything and don't order the measuring rod until you checked the length with the originals.
I did and it turned out the originals were the right length and I didn't even need the measuring rod.
good luck
good luck
