push rod lenght for afr 210
Old Jun 23, 2003 | 02:18 PM
gmlt1-76's Avatar
do's any know what the lenght is need when useing a solid roller cam with afr 210
Old Jun 23, 2003 | 07:46 PM
slopokrodrigez's Avatar
No-one can say definitely what size push rods would be needed. You have to measure for them. Once you have all the hardware assembled, you can use your original 7.2's to find out if you need longer or shorter. check out this page for information on how to measure. http://www.compcams.com/information/Products/Pushrods/
Once you find out if the new ones are longer or shorter than stock, then order a measuring rod and find the correct length according to the page listed above.
Don't assume anything and don't order the measuring rod until you checked the length with the originals.
I did and it turned out the originals were the right length and I didn't even need the measuring rod.
good luck
mrwz28
Jul 8, 2015 09:11 PM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
