Push rod
Old May 29, 2003 | 07:08 PM
z2894convertible's Avatar
Unhappy Push rod
How can I tell if I have a bent push rod. Also, will I loose power from it?
Old May 29, 2003 | 07:28 PM
I burn rice too's Avatar
Take it out of the car and roll it on a flat piece of glass or clear plastic. Look at it from all angles, even the bottom and if you have bent push rod you will definatly be able to tell. Hope this helps and yes you will lose power.
Old May 29, 2003 | 07:31 PM
Will this also cause me to get an SES light and for my idle to get real rough at times?
Old May 29, 2003 | 07:35 PM
madwolf's Avatar
You probably have an ignition problem. Doubt it's a pushrod. Get the car scanned and see what codes are set.
Old May 29, 2003 | 07:36 PM
The ses light shouldn't have anything to do with the push rods.
Old May 29, 2003 | 07:39 PM
The ses light doesnt stay on all of the time. It will come on for a few seconds and then go off. It still runs like crap even if the ses light isnt on. Will it show me the previous codes even if the ses light isnt on
Old May 29, 2003 | 08:07 PM
If your ses light is only on for a short while then your problem may have something to do with something internal. This is what I would do; get it scanned at Auto Zone or just somewhere, fix that problem and then see where you are at. You should also be able to find inactive codes. If that's not it, then check your push rods if that is what is determined. Don't forget that you could have a bad lifter also. I had a lifter eat up half of the lobe on my cam becuse it flat spotted.
Old May 29, 2003 | 08:09 PM
Oh yeah, what is it exactly that your engine is doing besides run bad.(Like backfiring ect .)
Old May 29, 2003 | 08:18 PM
I have lost alot of power and sometimes it idles just fine and sometimes it will barely idle at all
Old May 29, 2003 | 08:35 PM
Sounds more like an ignition problem. My guess would be OPTI.
Devinfoote87
Feb 12, 2016 03:21 PM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Boss002
Jul 24, 2015 10:47 AM
mrwz28
Jul 8, 2015 09:11 PM
