Pulling oil pan!!!
Old Apr 24, 2003 | 06:25 PM
1FastRedZ's Avatar
Pulling oil pan!!!
I have the damn oil cooler on my car. I'm trying to pull the pan and it hits the cooler. I have the part held in by the star drives out. Is there any way to pull the piece that the filter screws in off? Thanks.
Old Apr 25, 2003 | 12:39 AM
Lt1t56's Avatar
The oil cooler is easy to remove, one bolt holds the coolant lines to it, and once the oil filter is removed you need a big socket, something like a 1 1/8" socket, not for sure of the size, and unscrew the bolt ( where the oil filter mounts ) that mounts the cooler to the block.
Old Apr 25, 2003 | 01:20 AM
atljar's Avatar
Dont bother re-installing the cooler after your done. They do more harm than good. They pretty much bypass your oil filter once it gets the littlest amount of dirt in it.
jer4251
Sep 21, 2020 09:42 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
