pulling the motor from the top
Old Jan 10, 2004 | 01:08 PM
Quick96Z's Avatar
I know how incredibly simple this question may sound, but i just want to make sure i do everything right. When you guys pull the motor out the top, where do you put the bolts to use the engine hoist?? I can just envision me threading into a bolt hole that isn't very well supported, and snapping the bolt or having something randomly explode.
i owe you guys,
trav
Old Jan 10, 2004 | 01:11 PM
OneFlyn95z28's Avatar
I pull the intake and put the bolts in the one front and one rear intake bolt hole
Old Jan 10, 2004 | 01:16 PM
OBE1 95Z28's Avatar
TPIS sells a engine pulling bracket called the Happy Hooker. It mounts to the top of the intake manifold (so you don't have to remove the intake). It sells for around $40. I've used it several times and like the fact that you can mount the intake with the engine on an engine stand (easier to seal the intake).
Old Jan 10, 2004 | 01:39 PM
v7guy's Avatar
I had to carry the motor after it was out, so I pulled the top end off and put the bolts in where the heads bolt down to, it worked well, I think I'm buyin the TPIS piece or making one to install the motor though
Old Jan 10, 2004 | 01:54 PM
schpenxel's Avatar
I took the intake off and got myself some more clearance and a decent place to mount a chain, if you take the motor mounts off its a hell of a lot easier, and dont forget that clutch fork.
Carson
Old Jan 10, 2004 | 03:56 PM
I have used the happy hooker also.
I like the extra space I get with the intek off That is just me
Old Jan 10, 2004 | 04:29 PM
carlos64030's Avatar
There are some pictures in my signature with the intake off and placements of the hoist chains.
calaban
May 18, 2020 06:43 PM
transam_388
Mar 15, 2015 11:53 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
