Pulling motor... suggestions?
Old Jan 24, 2006 | 01:37 PM
96LT1TX's Avatar
Ok I finally found the time to pull this damn thing. I am going to go step by step w/ http://www.michiganspeed.com/enginepull/index.html
anyone use this? any kinks? anyone have better advice? I was wondering if since my heads will be off and intake manifold off does it come out of the top w/ those off easieR? The oil pan is also off.
I am in the garage! checking on this periodically (when I get pissed)
thanks
Old Jan 24, 2006 | 01:39 PM
96LT1TX's Avatar
Re: Pulling motor... suggestions?
also, I am thinking of keeping the transmission IN the car, if this makes it much harder however I do not want to do this. Please advise?
Old Jan 24, 2006 | 01:51 PM
streetrod93's Avatar
when i pulled mine this spring...the heads were still on, and the tranny was left under the car....if you already have this much taken apart...pull it from the top, it's not hard at all.
Old Jan 24, 2006 | 01:56 PM
96LT1TX's Avatar
not hard at all im buying a cherry picker, would that make it even easier? it will just be block (thats what i need to take to the machine shop )
Old Jan 24, 2006 | 01:58 PM
z96's Avatar
z96
I Followed The Same Directions I Removed Engine , Trans, K Member
From The Bottom Was Very Easy Had Engine On Dolly Rolling Around With In 5 1/2 Hrs. Very Easy.
Old Jan 24, 2006 | 02:09 PM
dreamer1q's Avatar
That really is a great write up Good luck, its not as hard as it seems, just take your time and use your head.
Old Jan 24, 2006 | 03:55 PM
96LT1TX's Avatar
ok so how do I put the chains on this block? The oil pan, heads, everything is off it. It is just the block... the last piston was in PIECES
I can get a cherry picker, and chains, so I just put them under the block and pull it up like that? thanks for the help
Old Jan 24, 2006 | 03:59 PM
jkipp84's Avatar
I got one of these: http://www.northerntool.com/webapp/w...3&storeId=6970
Notice on the end of the chains, those little tabs? I just got some short (1" or so) bolts with the same threads as head bolts and bolted one tab to the furthest bolt by #8 and closest by #1. Came right out, no problemo.
That leveler on the hoist can be bought separately if you already have a hoist, as well as just chains with the tabs. I didn't use the leveler, just the chains.
Old Jan 24, 2006 | 04:06 PM
96LT1TX's Avatar
yah, i can get that leveler, thanks a bunch man! Using the stock head bolts a bad idea for that or not? thanks again
Old Jan 24, 2006 | 04:12 PM
jkipp84's Avatar
Yeah, I don't think I'd use the stock bolts. Remember, they're not threaded all the way up to the bolt head. Just take a head bolt down to Home Depot, Lowes, etc, and find some bolts of the same pitch that are short. Shouldn't cost more than 50 cents.
Old Jan 24, 2006 | 11:53 PM
96LT1TX's Avatar
how long of a bolt do i want? grade 8? thanks again
Old Jan 25, 2006 | 03:25 AM
jkipp84's Avatar
Just a short one will be fine, about 1 or 2 inches.
Old Jan 25, 2006 | 05:24 AM
ss97dml's Avatar
use your old intake bolts,no leveler. just put the hoist hook towards the front and it will have the perfect angle to pull it.leave the tranny under car.
alex5366
Exhaust System
Mar 8, 2015 11:28 AM
cyteone
Feb 7, 2015 06:04 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
